Cruise Control Problem
Old Aug 12, 2010 | 01:16 AM
rusmannx's Avatar
rusmannx
Default Cruise Control Problem
I've searched around and not really found any other threads with my problem. At least not any that had solutions.
1. My cruise light comes on when I turn it on
2. Cruise does not engage and the other three buttons do nothing.
Anyone else has this problem or know how to solve?
Old Aug 12, 2010 | 09:05 AM
Dans01Durango's Avatar
Dans01Durango
Firstly, how about supplying us with the year, model, engine size of your D so we can help you better?
Old Aug 13, 2010 | 03:20 AM
rusmannx's Avatar
rusmannx
in the sig.... that doesn't seem to show up
2001 - 4.7
Old Aug 14, 2010 | 12:20 AM
master tech's Avatar
master tech
Site Moderator & Tech
First i would the vacuum source,at the intake manifold. Are there any other problems, like air bag lite on,door locks not locking at 18 mph or no overdrive?
Old Aug 14, 2010 | 03:18 AM
rusmannx's Avatar
rusmannx
nope. no other lights or problems. cruise and AC aren't working but i can only imagine they are not related. everything else is great.
Old Aug 14, 2010 | 04:13 AM
Mean Green's Avatar
Mean Green
Cruise and ac are both connected in one way. Vacuum controls the blend door and mode door in your HVAC system. If you lose vacuum to your HVAC system it will default to heat and defrost.
Old Aug 14, 2010 | 08:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sorry mean green, but he has an 01, those doors are mechanically actuated, so im still lost on the link
Old Aug 14, 2010 | 07:06 PM
Mean Green's Avatar
Mean Green
Are they mechanical on the later models D's? Mines vacuum controlled for the recirc and mode door. IIRC the blend door is mechanical on mine still. Hmmmm I was tired last night.
Old Aug 14, 2010 | 10:21 PM
shrpshtr325
THE ULTI-MOD
yea the later half of the gen (not sure if it start 00 or 01) are mechanically actuated by electronic motors, you are forgiven . . . this time
Old Aug 15, 2010 | 09:08 PM
hydrashocker's Avatar
hydrashocker
There are 2 things to look into:
1. A bad TPS but that usually includes surging of the motor in about 300 rpm when cruising down the hwy.
2. A bad brake switch above the brake petal.
