Need help with lift and tire seize?
Old Aug 12, 2010 | 01:28 AM
acehole420's Avatar
acehole420
Default Need help with lift and tire seize?
I have a 99 durango... I wanna lift it and the only suspension lift out there is 5.5 which is very expensive so i was thinking about goin with a 3 inch body and the 2inch lift out of the torsion bar.... That would give me 5 inches but what size tire should i look for if thats even a good idea?
Old Aug 12, 2010 | 04:46 PM
Duranged408's Avatar
Duranged408
With the body lift and t/s your looking at 33" tires.
With the 5.5" suspension lift your looking at 33" tires.
Your choice
The pictures below shows when i had a 3" body and t/s with 33"
Old Aug 12, 2010 | 05:26 PM
acehole420's Avatar
acehole420
Can i go with a 33 x 12.50 because i was told it might rub?
Old Aug 27, 2010 | 12:33 AM
juggaloword@yahoo.com's Avatar
you can go with that or you can buy leaf springs i got 9 leaf springs on my ford just add more leaf springs it will lift it up did it to my moms durrango 2002
Old Aug 27, 2010 | 01:38 AM
fpsweet's Avatar
fpsweet
I try to use web sites that have info on that stuff like 4wheelparts.com and a few others rim size changes i use discounttiredirect.com
