Code P0445
Old Aug 21, 2010 | 05:09 PM
mikesram's Avatar
mikesram
Default Code P0445
Anyone get this code? P0445 What was your find and fix? I need an idea where to start.
Thanks
Old Aug 21, 2010 | 05:23 PM
dolittle's Avatar
dolittle
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, and/or
Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary. I had this happen it was a split in one of the vacuum hoses going to the charcoal canister.
Old Aug 21, 2010 | 07:07 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup, check the charcoal canister, and all the lines in that area, 2nd most common cause of this problem (after a bad gas cap)
Old Aug 22, 2010 | 10:59 AM
Durango03's Avatar
Durango03
I had PO445 and PO442 come up on mine. I replaced my gas cap and then when that didnt get rid of the CEL I checked my cannister, here is the link to what I found with pics.
https://dodgeforum.com/forum/1st-gen...n-today-2.html
