less mpg after spark plug change
Old Sep 11, 2010 | 09:32 AM
TomQ's Avatar
TomQ
I am having the same problem, but installed a new 5.9 from Jasper a couple weeks ago and having poor gas mileage. How can I reboot the computer? or should I have the mechanic do it.
Old Sep 11, 2010 | 09:49 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by TomQ
a new 5.9
if you just put a brand new engine in, that is your problem, they need to break in before they will run at peak efficiency, and the fact that its a 5.9 is another part of the problem, they are NOT easy on gas
Old Sep 11, 2010 | 03:06 PM
hydrashocker's Avatar
hydrashocker
Yes you should reset the PCM:
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
