Any idea what is causing a hum in my Durango
Old Aug 24, 2010 | 06:28 PM
k9roo's Avatar
k9roo
Default Any idea what is causing a hum in my Durango
I have a 2000 Durango that has started making a humming/roaring kind of sound. You can hear it when you get up to about 25mph and it increases as you accelerate and decreases when you decelerate. I've noticed when I go around a left curve it stops however if I go around a right curve it still does it. This makes me think the issue is on the left side side since when I make a left curve it takes some of the weight off that side. I don't think its the wheel bearings because when we jacked it up to check it there was no slack in the wheel, it was tight. I also see that there is some wear on the inside of the left tire. I bought these tires 18 months ago and had a front end alignment done at the same time and they replaced the tie rods.
Anyone experienced the same problems or have any ideas what it could be? A coworker said it may be the rear axle bearing but the noise seems to be coming from the front.
Old Aug 24, 2010 | 07:29 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it sounds to me like the wheel bearing going out, when my first one went out it didnt move, all i had was the noise while driving, wasnt sloppy/loose or anything, just noisy.
on a similar note, i think i have my second one going out now
Old Aug 24, 2010 | 08:52 PM
hydrashocker's Avatar
hydrashocker
Drivers side front wheel bearing.
Old Aug 24, 2010 | 10:22 PM
dodgehoodup's Avatar
dodgehoodup
My wifes is making the same sound. Same thing you turn left it stops. I figured i will be changing it after winter.
Old Aug 24, 2010 | 10:35 PM
shrpshtr325
THE ULTI-MOD
i would wait if you dont have to, if it gets bad enough they can cause the tires to wear badly
Old Aug 24, 2010 | 11:20 PM
Dans01Durango's Avatar
Dans01Durango
+1 on driver's side bearing.... or is it +2?...
Old Aug 25, 2010 | 10:51 PM
hydrashocker
^ lol ^
Old Aug 28, 2010 | 02:48 PM
k9roo's Avatar
k9roo
Replaced the wheel bearing but its still not fixed.
Old Aug 28, 2010 | 11:24 PM
hydrashocker
Move the replaced wheel bearing to the other side.
