No (Front) Heat or A/C in 03 Durango
Old Sep 14, 2010 | 11:38 AM
-Lawless's Avatar
-Lawless
Well oh so recently I had what sounds like the same problem.
Mine was the relay located under the hood.
I'm not sure of the difference between the 99 and your '03 but I'll take a picture of it's location for you.
Old Sep 14, 2010 | 12:43 PM
-Lawless's Avatar
-Lawless
Here are some pictures:
Old Sep 15, 2010 | 12:32 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by dodgedriver03
Ok, took my durango to my dad, he tested the resistor (he's an electrician) and said it was good. Tested the fan, said it worked fine. He is now thinking the problem must be in the switch......
He's in the process of finding a new wiring harness. Any suggestions about the switch?
Thanks!
Dude, the harness is corroded all to hell! Cut it off and solder a new harness on from a junk yard!
Old Sep 15, 2010 | 02:45 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
your wire harness is shot and NEEDS to be replaced, i owuldnt even try to use the fan w/ that harness in there
