Help
Old Aug 28, 2010 | 11:21 AM
ZekeZeke's Avatar
ZekeZeke
Default Horn beeps and starter will not engage, Help
Ok here is the problem, when I try to start my 98 Durango the horn blows and the ignition will not engage. The key fob operates the door locks, and disengages the blinking security light on dash. What is wrong? Also there is a small, what looks like, rca jack to the right of the hood release that has a blinking red led, never noticed the blinking led before, what can it be? HELP!
Old Aug 28, 2010 | 11:17 PM
hydrashocker's Avatar
hydrashocker
Somebody has messed with the wiring!
Ensure your battery connections are clean.
Old Aug 29, 2010 | 01:08 AM
IndyDurango's Avatar
IndyDurango
It is the fail safe on the alarm.
Old Aug 29, 2010 | 06:30 PM
ZekeZeke's Avatar
ZekeZeke
well then how do I bypass it?
Old Aug 29, 2010 | 07:01 PM
dolittle's Avatar
dolittle
This sounds like a aftermarket system you will have to go to their web site or installer to diagnose it.
Old Aug 29, 2010 | 08:49 PM
ZekeZeke's Avatar
ZekeZeke
Its stock
Old Aug 29, 2010 | 09:41 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by ZekeZeke
Its stock
it could have been installed by the previous owner of the truck (unless you bought it new)
Old Aug 30, 2010 | 05:18 PM
hydrashocker
I know of no true way to actually bypass the OEM factory alarm correctly.
Old Aug 31, 2010 | 10:07 AM
Dans01Durango's Avatar
Dans01Durango
+1 on the aftermarket alarm. Most likely that's your culprit. Take it into an alarm shop and see if they can disconnect it or remove the alarm altogether.
