Constant Hum / Ticking noise HElp
Old May 27, 2005 | 12:33 PM
blackdodge's Avatar
blackdodge
Default Constant Hum / Ticking noise HElp
When I am coasting or not applying the gas I hear a constant ticking noise coming from the front end. Thought it was a stuck pad or caliper but Les Schwab said everything was a-ok. Anyone have a clue? It is the weirdest thing. Kind of like a card in the spoke of a bike. All is fine when applying the gas but as soon as my foot comes off the pedal it starts up. I think it's coming from the front end but is hard to tell ( exhaust system ) is pretty loud. Nothing visible under chassis, no leaks or excessive heat seen just an anoyying tickticktickick....any Ideas where to look?
2001 Durango SLT
Old Jun 3, 2005 | 11:35 PM
MAD 4X4's Avatar
MAD 4X4
Default RE: Constant Hum / Ticking noise HElp
Do you hear it when your outside of the car or only when inside the car? What grade of gas do you use?
Old Jun 5, 2005 | 02:54 AM
blackdodge's Avatar
blackdodge
I just use regualr gas(87). The noise is from the rear end I think. I took it to the dealer they drove it and said it needs new rear end!!! $2500.00 They didn't even look under the car( cost me $68.00 to let them drive my car around the block) The tech said that he knows that noise and that's what is. I think I need a second opinion. Anyone else heard this before. I checked the u joints and they are solid. What else can I look for? I've driven about 500 miles with the noise and nothings fallen off yet. I only hear it when I have my foot off the gas at over 25 miles per hour. Sounds like a card in a spoke. I figured it was something grinding it would have seized up or something by now. Help
[IMG]local://upfiles/10114/FC1AC2371DE547FDA1C67681FBB49E74.jpg[/IMG]
