Wiring durango for trailer?
Old Aug 30, 2010 | 06:52 AM
noman's Avatar
noman
Default Wiring durango for trailer?
Hello new to the site. I question is I'm wiring my durango with a flat 4 plug. How do I get the brakes and turn signal to run through the same wire? Since there is 6 wires going to the tail lights. left turn, right turn, tail, brakes, reverse, ground.
Old Aug 30, 2010 | 08:00 AM
mark38090's Avatar
mark38090
Hoppy Part Number 42215 for 1998-2003 durango
Hoppy Part Number 42245 for 2004-2007 durango
www.hopkinstowingsolutions.com
Old Aug 30, 2010 | 08:17 AM
noman's Avatar
noman
So you have to get a wiring harness? You can't do without it.
Old Aug 30, 2010 | 05:26 PM
hydrashocker's Avatar
hydrashocker
You could should have a 4 wire loom by the spare tire (coiled up) and the frame on the drivers side that has those wires already there. Get under the Durango and look for it. It will have your Right Tail, Left Tail, Park, and Ground for the 4 way already there.
Old Aug 30, 2010 | 06:07 PM
noman's Avatar
noman
I didn't find those wires. The only wires I found was the one going to the license plate. And near the gas tank going to the abs sensor.
