2001 Durango Rotor Change help
Old Sep 4, 2010 | 07:40 PM
emim's Avatar
emim
Default 2001 Durango Rotor Change help
hello all... I am planning to change the rotors and brakes on my 2001 durango.. any special tools that I will need? any tips/suggestions? When I checked them the brakes on the outside were fine but the inside rotor was a mess! all uneven and only the middle is holding... thanks for any help you may provide.
Old Sep 4, 2010 | 08:02 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
nope, no special tools, just the normal sockets and allen keys, not a hard thing to do, just make sure you dont hang the caliper by the brake hose, and dont touch the new rotor or brake pad with your hands
Old Sep 6, 2010 | 01:59 AM
IndyDurango's Avatar
IndyDurango
There is a nice tool for the rears. Not required, but makes drum brake swaps easier dealing with the springs, clamps etc.
Use a coat hanger to hold the front calipers up and a C clamp to push in the piston. remember to take the cap off the master cylinder and never run it dry.
IndyDurango
Old Sep 6, 2010 | 08:32 PM
emim's Avatar
emim
Ok.. Job done! Was easier than I ever thought! Thank you....
