Are 2000/01 MAP sensors interchangeable?
Old Sep 9, 2010 | 01:43 PM
rob497's Avatar
rob497
Default Are 2000/01 MAP sensors interchangeable?
P1080 comes up when I check the trouble code (on/off method). The price for my 2000 Durango is $$$$, but the price for the 2001 MAP sensor is less $$. The sensors LOOK the same, but are they?
Or does anyone know where I can buy a map sensor for less than $100.
Thank you
Old Sep 9, 2010 | 04:43 PM
hydrashocker's Avatar
hydrashocker
I see you have this:
Originally Posted by rob497
I have a 2000 Durango, 4WD.
However the motor size would help?
Here you will find them for under $100. www.rockauto.com But you can check a junk yard as well as they are not a normal part that goes bad.
Old Sep 10, 2010 | 01:44 PM
rob497's Avatar
rob497
Default Ooops
Its a 4.7 V8
Old Sep 10, 2010 | 02:46 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
chances are if the price is different then it is a sensor for a different engine size
but your sensor should look like this (cost $134)
the one for the 5.2/5.9 looks like (cost $88)
Old Sep 10, 2010 | 05:48 PM
hydrashocker
You can always pick up a junker to get you bey.
