Clutch pack disintegrating
Old Sep 16, 2010 | 09:20 AM
hydrashocker's Avatar
hydrashocker
We're good friends!
Anyway, you are the first person I have seen with a Chryser 9.25 with 3.55 ratio and a 5.9L. Regardless it's fine just haven't seen it, and it doesn't really matter anyway as the carrier will be the same anyway just a different pinion and ring gear tooth. Everthing will still apply.
Make sure you get every peice out because there is a oil sump between the pinion bearings and if a piece of clutch pack gets in there it can cease the bearing. Your best bet would be to pull the pinion out and ensure a good cleaning.
Are you planing a full rebuild?
Old Sep 16, 2010 | 10:34 PM
Belchfire's Avatar
Belchfire
I had a feeling you two were buddies. I'll pull it all apart and see. In a way, it's only 103K on it but then again, the clutch pack did start falling apart. I've done 60-second burnouts in my Duster with no issues, but as long as I've got this one apart, I'll at least replace bearings and seals. The gears looked fine and I probably won't be doing too many burnouts in it. I actually bought it for the 3rd seat and aftermarket DVD for the new grandkids. Many thanks -and your recommendations?
Old Sep 17, 2010 | 09:43 PM
hydrashocker
Doing burn outs on a LS rear end is really hard on them.
If the gears are fine then just a basic rebuild with new bearings and seals. Be careful not to ruin the shims on the Pinion (that are between the pinion gear end and the bearing next to it) look careful. You shouldn't need a new crush sleeve as you will have to compress it at just over 300 ft lbs torque then back off. I would just use the old one if you can get the right preload on the bearings.
