Trailer wiring ?
Old Sep 15, 2010 | 09:42 PM
swiss's Avatar
swiss
Default Trailer wiring ?
I snagged up a factory tow hitch and cut 7 pin factory plug and tried to get it wired in for the most part. I have a question about the stop/turn connections. On my Durango it has a separate pin for the turn pulse and the brake light. Am I suppose to run these together then to each side? My trailer has 1 bulb for brake and turn WTF... Also where exactly do I splice in the brake controller wire?
Old Sep 16, 2010 | 08:53 AM
swiss's Avatar
swiss
Bump sry its a 99 5.2l 2wd auto
Old Sep 16, 2010 | 10:22 AM
hydrashocker's Avatar
hydrashocker
DId you look for the factory 4 wire loom tucked up between the spare tire and drivers frame? Look REALLY hard and it should be there. It is only a 4 wire so if you want to run ACC, Reverse, and Trailer Brakes then you will have to run those leads. If you cannot locate this wire loom then you need to get a conversion box (at least for the 4 wire leads and you will still need to run the other 3).
>------BTW, you really don't need to bump in this section.
Old Sep 17, 2010 | 10:10 AM
Dans01Durango's Avatar
Dans01Durango
>-------Bump, I concur! About the no bumping needed.
Old Sep 17, 2010 | 09:51 PM
hydrashocker
LOL........Bump!.......
