Engine Swap Info
Old Sep 15, 2010 | 10:42 PM
bsocko's Avatar
bsocko
Default Engine Swap Info
HI Guys,
I have a friend that has a 2000 Durango with a freshly blown up the engine. The current engine is a 4.7 V8. I have done lots of reading and I know the engine is 16T tone ring.
What year engines can I use for this SUV? Also does anyone have directions to swap out the tone ring?
Lastly I can get my hands on a 06 4.7 engine very cheap, would this work? Or would it not work since it is across generations?
Thanks,
Bryan
Old Sep 15, 2010 | 11:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yes you should be able to swap the tone rings (i have read about it being done, but cant seem to find it right now), i believe for the 2000 you need to stick w/ a pre-03 engine due to a computer system change for 03, your best bet is to find one from a 00 to swap in, that would be plug and play (kinda)
Old Sep 16, 2010 | 09:56 AM
hydrashocker's Avatar
hydrashocker
+1 Sharps
They are different so I would stay 00-03 years. I think one of the biggest differences is a cam sensor and that is a different tooth as well as some other internal differences. There was one person that was going to try the swap with an 2006 in a 2002 Durango 32 tooth but never heard back from them. The tone ring is on the fly wheel so swap them and ensure.
