Gas cap Pressure
Help, I have a p0440 check engine code. I was wondering if my gas cap should have pressure build up when I take it off. Mine does not. I'm trying to narrow down the problem. I have already replaced all the hoses to evap systems.
The system CAN have pressure but after the purge valve opens the vapor is burned so there would be no pressure. So to go directly off a no pressure instance one cannot tell if it is working. I would just replace the gas cap with one that is NOT vented.
