Remote door locks
Old Sep 26, 2010 | 04:41 AM
sck165's Avatar
sck165
Question Remote door locks
I have a 2003 Durango SLT .. The door remotes stoped working. I changed the batterys and they still don't work. when I push the lock or unlock when i set in the car and the dome lights are on they will flicker a little. So it makes me beleave the remotes are working. Is there some kind of way to reset the unit in the car that makes the doors lock? Or is this a common problem with an easy fix?? Thanks for any help..
Old Sep 28, 2010 | 10:45 AM
hydrashocker's Avatar
hydrashocker
There is also a type of reset that turns on and off the horn that you could try. I don't remember how to do it for different years but you can look it up in your owners manual.
Also here is an alarm reset for the OEM system. If you have an aftermarket system you will need to take it to the alarm service station.
Originally Posted by hydrashocker
Put lock all the doors manually and close all doors with the drivers door shut lastly. Insert the key into the drivers side door and turn it like you are trying to lock it (counter clock). Now turn it all the way to the other side like you are trying to unlock the door (clock) and you will see the lock come up. Now turn the key to the middle position and remove key. Now open the door. DO NOT USE THE KEY FOB WHILE DOING THIS.
This is how to complete a full reset of the alarm.
Hope it fixes the issue!
