All Power Windows dont work
Old Sep 26, 2010 | 10:46 PM
PeteL's Avatar
PeteL
Default All Power Windows dont work
2003 Durango 108000 miles.
Had driver side motor replaced 2-3 months ago. (Door slammed window dropped and broke the closed loop motor system.)
They where all working fine and today out of the blue all 4 windows stopped working.
Replaced 2 fuses one 25 amp inside fuse box and one 50 amp under the hood fusebox. ALL still not working.
The power door locks and power mirror adjustments still work from driver side door control (just not the windows).
Tried the individual door power and still dont work.
Any ideas on what to look for would be appreciated.
Thanx
Pete
Old Sep 26, 2010 | 11:15 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would replace the master control panel for the windows (the one in the drivers door) sounds like that unit is gone bad (shorted out, or maybe damaged some other way)
Old Sep 26, 2010 | 11:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would put out the master switch like shapshtr had said, but i would start checking power and ground with a 12 volt test light. You could have a bad switch or a broken wire inside the door jam.
Old Sep 27, 2010 | 09:53 AM
Dans01Durango's Avatar
Dans01Durango
+2 on the master control switch on driver's door. Take a flathead screwdriver and gently pry off the control panel. Should come off w/o any screws and test with test light to find continuity.
Old Sep 27, 2010 | 06:43 PM
PeteL's Avatar
PeteL
Default Fixed
Thanks for the advice.
Took the driver door panel off unseated and reseated the connectors and they are all working fine now.
Did note that the Window Lock does not work now but I can live with that.
Something must have shorted it.
Thanks again you guys do a great service sharing your knowledge.
Old Sep 28, 2010 | 02:05 PM
Dans01Durango
NP. Glad you found out the problem and fixed it.
