Abs & Brake light
Old 10-02-2010, 12:54 PM
Rango360's Avatar
Rango360
Rango360 is offline
Default Abs & Brake light
Hi guys
I was just wondering if its easy to remove the abs and brake light bulb behind the dashboard,the reason i want to do that is because i am tired of seen the lights on
Ps: Dodge told me i need a new ABS module but i wont go that route
Old 10-02-2010, 02:01 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Yes,
however you can go to a junk yard and find a Durango with the same ABS system you have and pull the module and swap for yours and fix the problem for a few bucks!
Get one from the same year with either 2 wheel or 3 wheel ABS whatever yours is.
Old 10-02-2010, 09:03 PM
Rango360's Avatar
Rango360
Rango360 is offline
Originally Posted by hydrashocker
Yes,
Well i was told if i get another one i will have to get it programmed to my vin number, now i have no idea if thats true or not?
Old 10-03-2010, 10:45 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
afaik the module doesnt need to be programmed, but i believe you need the drbIII tool to cycle the abs module in order to bleed it properly
Old 10-04-2010, 06:46 PM
hydrashocker
To bleed the pump, not just the little ABS electrical module (which is the ABS computer module).
There are 2 parts to the unit. The electric and the hydraulic.
Quick Reply: Abs & Brake light
