this darn chime
Old Oct 16, 2010 | 06:16 PM
iicon3's Avatar
iicon3
Default this darn chime
gotta 98 d 5.2 i will be driving like normal then i get the chime that sounds like the dummy gas light turns on.but there isnt nothing laminated.no lights saying anything.no check engine no door ajar.nothing whats going on.
Old Oct 16, 2010 | 09:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check ALL of your gauges when this happens, especially the oil pressure, water temp, and battery, if any are pegged (low or high) that is were to start looking
Old Oct 18, 2010 | 10:02 AM
Dans01Durango's Avatar
Dans01Durango
Turn the music up?...
Old Oct 18, 2010 | 04:40 PM
shrpshtr325
THE ULTI-MOD
lmao dan, hes trying fix the issue, not make it easier to ignore . . .
Old Oct 19, 2010 | 11:29 AM
hydrashocker's Avatar
hydrashocker
Sounds like a bad cell in the battery. If you have a "floating" cell if you hit a bump just right it can jar the cell and it tilts over and grounds the battery therefore grounding the system. This causes the system to think you turned off and on the key switch and all the lights will come on and it will chime.
Go have your battery load tested to confirm.
