Low RPM hesitation problem
Old Oct 19, 2010 | 11:40 AM
Forcedinduction's Avatar
Forcedinduction
Default Low RPM hesitation problem
Just had my motor replaced. It has about 30K on it. It has a rough idle and stalls when i come to stops or even sometimes when i shift gears. When i go to take off it stutters real bad and after 3 grand it runs perfectly fine.
I had a couple engine codes for two coils and a evap leak. Well i changed the coils and still the same. I ended up buying a new ECM and still the same problems. Any help would be awsome.
