HELP! Gen 1 window issue
Old Oct 20, 2010 | 08:54 PM
jmalin72207's Avatar
jmalin72207
Default HELP! Gen 1 window issue
So the other day I was driving the Durango, rolled the window down to see out of it then rolled it back up once on the road. About 30 seconds later I hear a real loud bang. I almost though someone hit the truck with a rock. Then noticed the window wouldnt roll up or down. I took the panel off and looked inside. I found a cable coming from the motor wasnt where it should be. Also there were a couple of plastic holders and glides in the door and the cable wasnt on them. Does anyone have a micro fiche of the parts and cable routing?
Old Oct 20, 2010 | 10:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you most likely need to replace the track assembly, either pull it from a junkyard or check e-bay for one.
Old Oct 21, 2010 | 12:14 AM
IndyDurango's Avatar
IndyDurango
http://www.windowmotor.com/
Old Oct 24, 2010 | 11:45 PM
jmalin72207
the motor is NOT bad. I just need a diagram showing how this cable is supposed to be run and prefer a micro fiche on the door
Old Oct 26, 2010 | 01:14 PM
hydrashocker's Avatar
hydrashocker
Get a manual: http://www.mediafire.com/?sharekey=c...b5ba589d1986ba
