Engine Change
technically, yes
HOWEVER i would NOT recommend it as in order to put a 5.9 into your truck you would need to replace the engine (duh), wiring harness, pcm, motor mounts, transmission and t-case (might as well just replace the driveline at this point). so in reality, NO it is NOT cheaper to put a 5.9 in than to replace with a 4.7
Practically, as indicated, no.
You need the engine AND transmission to do that.
Pull your own 4.7L for $189. That's not expensive.
http://www.indypicapart.com/
IndyDurango
IndyDurango
