Removing a torque converter
Old Nov 5, 2010 | 08:07 AM
DGauss's Avatar
DGauss
Default Removing a torque converter
Throwing trq conv lock up code. No driving issues yet. Can the trans and transfer case be pulled as one? Is there enough ground clearance to do it on jack stands or do you have to be on a lift?
Dave G
Old Nov 5, 2010 | 10:55 PM
Fox Fader's Avatar
Fox Fader
I've done a 300ZX on jack stands, so I can't see why you couldn't here.
Old Nov 7, 2010 | 12:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
No it can not. You need to remove the transfer case first,then lower the exhaust and remove the transmission.
Old Nov 8, 2010 | 09:49 AM
Dans01Durango's Avatar
Dans01Durango
Listen to MT, he knows his stuff.
