33x12.5 r18?
http://i54.tinypic.com/jzikxi.jpg
i have a 99 4wd durango, currently its on little 30x9.5's but as you can see the body still seems to sit higher then it should. i'm unsure if the person before me torsion cranked it? also it has extra leaf springs because it was used for towing, so could that be whats giving it the extra height?
either way, i use to run 32x11.5 r17's without rubbing, the front was shaved a bit but i never rubbed. i recently bought 33x12.5's, i was wondering how bad the rub would be if any? also what would be the least work done & least money to make it drivable on 33x12.5's
thank you
thank you
couldnt find polyurethane, don't know if it would spell it out for me in the description but what about this one?
http://www.suspensionconnection.com/...con/60003.html
