99 durango just shuts off
Im a newbie to this forum i recently just go myself a 99 d 5.2 slt towing package. Anyways lastnight i took it to the car wash and washed it and stopped by my buddies garage i left it sit outside and run was in there b/s and when i came out it wasnt running so i hoped in and cranked nothing happened so looking over stuffing i wiggled the connection on the computer the one nearest the fire wall and started back up and acted as if nothing happened runs fine and after this im kinda leary about driving it. So ive been doing me research on here and i come to find the 99s pcm are prone to failure could that be what it is? Thanks jim.
ok well i checked them and the guy i had gotten it from i called him today and he said the when it shuts off the you gotta mess with that black plug on the computer so could there be somthing bad gone on in the computer i took the computer out today top look at iut and the bottom looks like it got drug down the road and its all messed up so could in fact the computer be a boat anchor and just go get myself another one?
Well I would make sure you are getting a good connection first at the harness. If you continue to have issues then I would replace it. Personally, the PCM's they used in 1999 should be the same as those used in 1998 and they don't have the problem? Not sure if there was a bad batch that went out or not?
Anyway, if it looks like an anchor from abuse then I would think it most likely came out of a junk yard or something where they didn't care about it. It might be you best choice to replace it. If you do I would get one shipped to your door PRE-flashed for direct install. You can find re-builders on ebay. Look for companies that have lots of transactions and great feed back.
usually if wigging wires fixes it, the problem is a bad/dirty connection, now this bad connection could (in theory, iv never seen it happen) bee a connection from the plug to the circuit board which would require a replacement of the pcm in order to fix
thats what i happened to think it was aswell when i got it took and put eletric grease on the connections to ensure they wasnt dirty so i guess ill havce the replece the pcm. thanks again guys with your help
update so the guy i wokr for gave me a computer out of a v8 dakota i think its a i put it in my durango its fires right up the lights come oin as they should and go out everything works expect the doors dont lock after 15 mph and it runs like a b*tch to so im not sure should i leave it alone?
Trending Topics
ok well i was doing research and came across how to turn the auto locking on and apparently it was off because now it work will i be ok using the pcm until i get another i cant still plug my code scanner into my d and everything works as it should
