Parts question??
Old Nov 10, 2010 | 01:49 PM
big_nasty's Avatar
big_nasty
Default Parts question??
I have a 2000 durango slt and I need some parts, window regulators both sides front and a heater core, I found a 98 donor but I am not sure if everything will fit, are they the same parts for different years? I am questionable about the heater core because I believe it may have had a different size engine. Any help would be appreciated.
Old Nov 10, 2010 | 10:28 PM
IndyDurango's Avatar
IndyDurango
Window regs will be fine on the swap.
Core will be fine on the swap.
With that said, never use a used core. Too much trouble to change the core and then put in an old used one. Not smart. Buy a new OEM one.
IndyD
Old Nov 10, 2010 | 10:56 PM
old timer's Avatar
old timer
if u have to use a used core pour vinegar into it which will clean most of the deposits out of it. leave it in there over night at least but longer would be better.
Old Nov 11, 2010 | 12:53 AM
Thax's Avatar
Thax
The window regulators should work just fine, but the heater core is most likely going to be different and like indy said using a used one it just doesnt make sense a new one is about 40-50 bucks at a parts store.
