Clutch Fan Replacement
Old Nov 15, 2010 | 11:34 AM
jbriscoe's Avatar
jbriscoe
Default Clutch Fan Replacement
I have the 1999 D 5.9L. I am wanting to replace the clutch fan with Electric to fix the cooling issue. This model does not come with a eletric fan to assist with A/C, its a clutch only D. I would like to find some numbers on what the clutch fan is actually pulling. How much CFM at idle and how much CFM at full speed. I want to make sure what I get is better than what have now so I am not wasting my time. As well if anyone has done this actual swap show me exactly what you got to make it all work. I really do not want a switch in the cabin to turn the fan off and on. I prefer a auto setup so it will turn itself on.
Old Nov 15, 2010 | 02:15 PM
Dans01Durango's Avatar
Dans01Durango
There are alot of writeups about replacing the efan. There's a membe rthat I know of who did it and it came out very well. His handle is IndyDurango. PM him for more info.
Old Nov 16, 2010 | 12:09 AM
IndyDurango's Avatar
IndyDurango
It's all in here: All Electric Fan Swap + Much More.
Review the entire thread and you're set.
IndyDurango
Old Nov 16, 2010 | 12:32 AM
hydrashocker's Avatar
hydrashocker
There is lots of info here: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
Old Nov 16, 2010 | 01:50 AM
IndyDurango
In the end, those both get you to the same setup I have outlined above. Lots of discussion, some movement in other directions, troubles and miscues, decided direction to listen and try what was proven by others before hand, final result is the same thing. That's why Dan recommended my details I believe.
I am wrong sometimes... just not in the last two decades.
j/k
IndyD
Old Nov 16, 2010 | 09:06 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
but isnt durango club one that you have to pay to be a member of? (i might be nuts, i know there is one out there)
Old Nov 16, 2010 | 09:37 AM
Dans01Durango
You got a PM!
Old Nov 16, 2010 | 03:00 PM
IndyDurango
I happen to be the membership director SS.
No it is not a pay to use site. The forum is free to use for anyone, just like here with less ads.
If you want to be a supporting member there, you get other advantages. That simple.
What's the cloak and dagger PM Dan?
IndyD
Old Nov 16, 2010 | 03:21 PM
shrpshtr325
THE ULTI-MOD
he gave me the same information you did via pm, lol i got all screwed up, i thought you had to pay in order to post over there apparently iv been corrected, thanks
Old Nov 16, 2010 | 10:55 PM
IndyDurango
Cool. I have links there in posts that link back to DF here and vice versa. It's all about helping folks. I just won't re-write a thread in two places. Maybe a trouble/problem post on a failed part, etc..., but not a full thread.
IndyD
