HID Vrs. Projection
Old Nov 21, 2010 | 07:18 PM
sparkmarv's Avatar
sparkmarv
Question HID Vrs. Projection
I just whant some opinions:
What would be a better choice for my 99 slt, HID or Projection?
Which is brighter,
Ease to install,
Last longer,
ect...??
Also what brand of wich you would recommend.
Old Nov 21, 2010 | 07:42 PM
sparkmarv's Avatar
sparkmarv
Probally be leaning towards the Projections, hope their legal.
NO XENON HID conversion kit available from any source is DOT approved if installed outside of the factory <<is that true?
Also are the sylvania lights worth $40, they are only gaurenteed for up to 1 year. Do they dull out quick?
I JUST WHANT THE BEST HEADLIGHTS I CAN GET FOR $200.00
Old Nov 21, 2010 | 09:05 PM
IndyDurango's Avatar
IndyDurango
Piaa Xtreme White Plus
Old Nov 21, 2010 | 09:53 PM
sparkmarv's Avatar
sparkmarv
Thx, i like those, and only $100.
Are there wipers any good, they look nice, but 50$ for the Forza's, is that really worth it?
Plz anyone else is welcome to post some comments.
Old Nov 21, 2010 | 09:57 PM
sparkmarv's Avatar
sparkmarv
speaking of bulbs i also found this, might be useful to some.
1999 Dodge Durango Car Light Bulb Size Guide
Low Beam Headlight Bulb Size: 9007
High Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: 893 or 899
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 3057
Front Side Marker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 3057
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 579
Dome Light Bulb Size: 211-2
Step/Courtesy Light Bulb Size: 579 or 904
Trunk/Cargo Area Light Bulb Size: 567
Under Hood Light Bulb Size: 561
Instrument-General Light Bulb Size: 161 or 74 or PC194
Check Engine Indicator Light Bulb Size: PC194
Hi-Beam Indicator Light Bulb Size: PC194
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC194
Directional Signal Indicator Light Bulb Size: PC194
Ignition Switch Light Bulb Size: 53
Credit goes to: http://www.modifiedlife.com/1999-dod...lb-size-guide/
Old Nov 22, 2010 | 09:44 AM
Dans01Durango's Avatar
Dans01Durango
If you install an HID kit into your existing headlight housing, you may get a spraying effect with the light output. That means the beams may not be focused enough for safe night driving. Projection housings help in focusing the HIDs into manageable beams for driving. I got lucky when I installed my HIDs, the aftermarket crystal headlight housings were a good match for the HIDs.
Yeah, it's not DOT certified if you install aftermarket HIDs outside the factory. But the law generally doesn't really bust your chops unless you try to blind oncoming traffic! LOL! That's why I aim my beams lower than usual but they still light up the road like the sun. HTH.
Oh yeah, I did a comparison when I installed the HIDs with the silverstar ultras I had. Big difference, the silverstars were dimmer than the HIDs.
Old Nov 22, 2010 | 11:02 AM
WhiteWidow00's Avatar
WhiteWidow00
I have a HID kit on my 2000 Durango and I love it! It's an ease to install and it's much brighter than the projector.
As far as ease goes, HID all the way and as far as lasting the longest same answer. I have the 10k lumens and I can see anything and everything even in the darkest nights.
The projector are pointed at one specific angle so if they are not installed correctly, things can go horribly wrong. Not to mention, you need a new housing and bulbs run about $70 a pop for projection bulbs. My full install out of pocket for my HID bulbs off eBay was $80.
Make sure when you get them it comes with the ballast and bulbs, as for with HID it requires a special convertor ballast.
IMO I believe the HID would be the smarter more practical choice for our rigs.
Hope this helped
Old Nov 22, 2010 | 12:28 PM
gr8scott72's Avatar
gr8scott72
Hope this helped
Great! Another driver that sees nothing wrong with blinding oncoming traffic. HIDs are about 4 times brighter than Halogen lights. If you use them in regular (stock) housings, you WILL blind oncoming traffic since the stock housings don't have the correct cut-off pattern that projector housings do.
Prove me wrong. Pull up to a wall at night and take a picture of your cut-off pattern. You will probably see many stray beams above the main concentration on light. This is what blinds everyone.
You say projector housing bulbs are $70 each? Usually they are just normal bulbs in the projector housing.
The correct way to do it is to use projector housings for you HID and then aim them properly.
Old Nov 22, 2010 | 03:18 PM
WhiteWidow00
Agreed Scott. Although he was asking for which was brighter, easier to install, and which last longer. It would last the same if you put your HID bulb in a projector housing, but comparing projector to HID in stock housing, the stock housing is much brighter.
But as you said it is much brighter and I forgot to mention I have my stock housings aimed low. Also, I have a BMW which utilizes projector lamps OEM and they are a special bulb that cost in the ballpark of $70 each just for the bulb.
Not sure but wouldn't doubt in a aftermarket housing that its just a regular bulb with a lens in front of it.
Old Nov 22, 2010 | 03:29 PM
sparkmarv's Avatar
sparkmarv
So would this be ok? http://cgi.ebay.com/ebaymotors/HID-1...Q5fAccessories
