Rear axle ratio?
Old Nov 23, 2010 | 06:25 PM
Jordan91ulbrich's Avatar
Jordan91ulbrich
Default Rear axle ratio?
the tag on my 1998 durango for the rear axle says 3.9 or just 39 so what is my rear axle ratio because i need to start looking for a new ring gear or hole new axle.
Old Nov 23, 2010 | 09:17 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
probably 3.92 as that is the closest ratio to 3.9
Old Nov 23, 2010 | 09:39 PM
Jordan91ulbrich
thanks,
Old Nov 23, 2010 | 10:34 PM
hydrashocker's Avatar
hydrashocker
If it says 39 on the rear tag on the differential then it is a 3.92.
Old Nov 24, 2010 | 03:39 PM
Jordan91ulbrich
isnt the axle under it a 9.25?
Old Nov 24, 2010 | 04:22 PM
hydrashocker
There are two different axles in the Durango.
There is a Chrysler 8.25 and a Chrysler 9.25........First you need to find out which one you got then go from there.
I think the 9.25 has a 12 bolt cover and 8.25 is only 10. You can also get a build sheet for your Durango that will have all the information you need. You can email Dodge, call Dodge service or go into a Dodge parts center and have them print you off one.
Old Dec 13, 2010 | 11:26 PM
Jordan91ulbrich
How do i Email Dodge to get my build sheet.
Old Dec 14, 2010 | 03:01 AM
Biff85ta's Avatar
Biff85ta
Go to the dodge website and use the customer assistance to request one.
Old Dec 14, 2010 | 04:21 AM
bwdakrt's Avatar
bwdakrt
There should be a sticker inside your glove compartment that will give you all the info on the rear diff specs.
Old Dec 14, 2010 | 07:24 AM
shrpshtr325
THE ULTI-MOD
dodge.com/owners should be under the contact us section
