Tranny maintenance ?
Old Nov 24, 2010 | 05:15 PM
sparkmarv's Avatar
sparkmarv
Question Tranny maintenance ?
Im just wondering what its gonna cost me to have a mechanic shop change my tranny fluid ,filter, diff, and transfer case fluid. Also wanna have my bands adjusted. I know most of you probally do this yourself, but i know a few have had to take it to a shop one time or another.
I just wanna ball park figure.
O, also wanna have them install a drain plug, so i'd wanna change my own fluid in the future.
Once i get this taken care of i can start with some mods , cant wait cuz i love my D the more and more i drive it.
Old Nov 24, 2010 | 11:01 PM
IndyDurango's Avatar
IndyDurango
Do the Diffs too. Pick a good local trans shop.
$350 including all materials that you provide. Don't use their shop fluids.
$850 if the stealer does it.
IndyD
Old Nov 25, 2010 | 12:35 AM
sparkmarv's Avatar
sparkmarv
thx indy, I wanna get that done after the holidays
Old Nov 25, 2010 | 12:32 PM
hydrashocker's Avatar
hydrashocker
Mine was $450 for Full Synthetic but the shop I go to isn't the cheapest and I needed him to do it for me.
Old Nov 25, 2010 | 02:00 PM
sparkmarv's Avatar
sparkmarv
99 SLT w/5.9l 4x4.
could you give me a complete list of the things i would provide? I ask because i wanna have this done correctly, and as cheap as possible(im only 24, supporting myself, not a whole lotta money to go around).
Also, would it save me some money if i just had the tranny fluid/filter changed, and bands adjusted, how much in your opinion would this run me. What fluid atf+4, what brand? How much? what brand of filter?
Is the transfer case fluid as easy as this: http://www.ehow.com/how_4830936_chan...ase-fluid.html?
Any specifics on what fluid, and how much, as ive never done this before, my first 4wheel drv. Also i cant imagine being able to fill with a funnel under there, or can you access it from engine bay?
How about the diffs, what fluid for them, and how much for each. As ive never done this before, how do you drain them first of ALL, drain plug? When adding fluid you just fill them all the way up, right?
Whole lotta noob questions, but i have to learn some how.
Old Nov 26, 2010 | 02:45 PM
hydrashocker
Yes the T-case is that easy but you will need a cone nipple like that on a bottle of 90W-80 gear oil on the top of the ATF+4 Fluid bottle. Yes the T-Case takes ATF+4. Just get some Valvoline about 2 quarts and you will want to pick up a little clear hose to attach to the cone so you can get the new fluid bac in it. Fill to the bottom of the top fill plug. You might see a little fluid come out and that is ok.
Transmission needs ATF+4 about 8 quarts and a new filter. Dealer ship our your local parts store. Again I like Valvoline. Best bet is to take it in and have a professional do this for you. About $130. Ensure they only use ATF+4 fluid ONLY!
Rear Diff is like 3-4 quarts 80W-90 I like Mobil One. If you have a Limited Slip Rear end then install the 7oz bottle of Friction Modified first before fill up. Auto Zone has this for $4.99, use entire bottle. Fill to the bottom of the fill plug.
Front is about 2 quarts 80W-90 I like Mobil One. Fill to the bottom of the fill plug.
Get a manual and it will tell and show you how to do this.
Old Nov 26, 2010 | 11:23 PM
sparkmarv's Avatar
sparkmarv
Thx hydra
Old Nov 27, 2010 | 01:00 AM
IndyDurango
Its 75W-90 BTW for the DIFs, not 80w-90. +1 on Mobil1. Get the $9 limited slip additive from the stealer if you want Mopar on it for the rear (not need up front)
IndyD
Old Nov 27, 2010 | 02:49 PM
hydrashocker
IndyD
That is incorrect. The gear oil needed by the owners manual is 80W-90.
Fully Synthetic versions are 75W-90, and that replaces the 80W-90 conventional version of oil. The reason theat 75W-90 Fully Syinthetic was placed in the rear on OEM in the Chrysler 9.25 rear differential was because that differential was meant for towing so it had a better oil from the factory that could handle the shearing that regular conventional oil breaks down from the added heat and ware. The Chrysler 9.25 differential was the rear differential, and that is why it had the Fully Synthetic oil, where the front was not subjected to towing heat like the rear so it didn't need the extra protection.
FRONT AXLE
² The lubricant should have MIL-L-2105C and
API GL 5 quality specifications.
² Lubricant is a thermally stable SAE 80W-90
gear lubricant.
REAR AXLE
² 8 1/4 lubricant is a thermally stable SAE
80W-90 gear lubricant.
² 9 1/4 lubricant is a thermally stable SAE
75W-90 gear lubricant.
NOTE: Trac-lok™ equipped axles require a friction
modifier be added to the lubricant.
Old Nov 27, 2010 | 09:48 PM
sparkmarv's Avatar
sparkmarv
So we will say $150 for fluid/filter change, what should the ban adjustment.
