starting problem
Old Dec 3, 2010 | 04:56 PM
crazy5269's Avatar
crazy5269
Default starting problem
Hi
my 98 d with 5.9 4x4 is having an intermittant starting problem
occasionally it wont start you can crank it and hold the gas pedal down and it will start then as soon as you let off the gass it stops.
but if it remove the negative battery cable for a minute and reconnect it it fires up fine
no codes come up and no check engine light
any ideas thanks
Old Dec 3, 2010 | 08:32 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
bad battery or bad IAC motor, if you hold the gas in long enough will it stay running? (this is pretty typical of the IAC motor)
Old Dec 3, 2010 | 09:45 PM
hydrashocker's Avatar
hydrashocker
Clean the terminals really good and possible bad battery.
Old Dec 3, 2010 | 11:01 PM
crazy5269's Avatar
crazy5269
no it wont stay running
and it;s a brand new battery about two months old
Old Dec 5, 2010 | 09:35 PM
hydrashocker
Replace the IAC and clean your Throttle Body. https://dodgeforum.com/forum/1st-gen...ttle-body.html Then reset the PCM: https://dodgeforum.com/forum/1st-gen...ine-light.html
