door question
Old Dec 6, 2010 | 11:18 PM
tom ringler's Avatar
tom ringler
Default door question
i have two questions for you guys i have a 99 durango and the drivers door lock is not working. i am wondering if you guys think my master switch is going bad. the switch will work all door but the drivers door for the locks. the reason i am trying to get this fixed is so i can put my remote start on the truck.
my dashlight for the fourwheel drive does not light up when in four wheel drive.
any help will be good
Old Dec 7, 2010 | 10:13 AM
tom ringler
please any ideas out there
Old Dec 7, 2010 | 11:26 AM
DurangoRT/RN's Avatar
DurangoRT/RN
I have replaced the driver side window three times on mine. Right now it does not work and I just noticed the lock occassionally does not catch when I use the remote.
Seems to be a power issue on mine.
This is one thing I am taking my truck to get fixed for...
Old Dec 7, 2010 | 11:16 PM
hydrashocker's Avatar
hydrashocker
Use a Multi-Meter and see if the switch is bad or the motor is bad, or bad connections.
You could have a bad bulb or a bad Transfer Case Switch (which the case switch is most likey the issue). It is located by the linkage of the T-case, or above it depending on your T-case for the 1999.
Try to keep your questions seporate in their own threads. This aids in members using the Search Feature and keeping things neat.
