Keeping Battery Terminals Clean
Old Dec 7, 2010 | 03:09 PM
02 Durango_R/T's Avatar
02 Durango_R/T
Default Keeping Battery Terminals Clean
I have 2 vehicles - a Jeep 4x4 stationwagon & a Durango. The battery terminals on the D are always extremely corroded while the Jeep stays clean. I have cleaned the D's terminals 3 times without touching the Jeep's. Is there something I need to know? Any little tricks to fix this? I know it might seem like a silly question, but I'm baffled.
Thx
Old Dec 7, 2010 | 05:03 PM
Pwall's Avatar
Pwall
the battery maybe leaking at the terminal and spay some corrosion preventive on it
Old Dec 7, 2010 | 09:47 PM
Fox Fader's Avatar
Fox Fader
Use the red and green washers found in auto parts stores.
Spray them with that red stuff.
Cover the terminals with bearing grease.
Adhere a penny atop the battery centered between the terminals.
Old Dec 8, 2010 | 12:04 AM
hydrashocker's Avatar
hydrashocker
+1 Fox
Never heard of the penny thing? Please elaborate on this (copper) idea? http://www.howtocleanstuff.net/auto/...ery-terminals/
Old Dec 8, 2010 | 04:24 PM
02 Durango_R/T
Awesome. Thanks. Will try this as soon as I get a warm day out.
To echo Hydra: what's with the penny?
Old Dec 8, 2010 | 04:36 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you read the thread of comments in the link that hydra poster, there is someone there who explains that the zinc in modern pennies is likely acting like a sacrificial annode and corroding instead of the battery terminals, this is because zinc is a more reactive element than whatever is used in the battery terminals, however i have never had a problem with excessive corrosion on battery terminals
that thread also states that the corrosion is caused by either too loose a connection or overcharging (i believe it was in that link, if someone reads it and tells me im wrong ill go looking for where i read it)
