Starting issues I need help !!
Old Dec 11, 2010 | 10:33 PM
agobbie's Avatar
agobbie
Question Starting issues I need help !!
02 Durango 4.7 2wd. Car wil start fine when it is cold, drives great. But when I stop and try to start it again it will not start !?!?!?!!? Leave it for about 45 mins and then it starts right back up ! Any body got any suggestions Im Stumped !
Old Dec 12, 2010 | 12:01 AM
WhiteWidow00's Avatar
WhiteWidow00
Check the battery first for voltage draw. Also, when you go to start it and it doesn't start does it crank or just make a click? Details would help us get an idea what's going on.
Old Dec 12, 2010 | 03:29 PM
agobbie's Avatar
agobbie
it cranks and trys to start
Old Dec 12, 2010 | 03:56 PM
WhiteWidow00
Check and insure the cables on the battery are secure especially on top post batteries. Next if that does nothing I would put some fuel injector cleaner in the tank (STP makes a good product and I personally use Lucas) as it coul be dirty fuel injectors.
Old Dec 12, 2010 | 05:29 PM
agobbie's Avatar
agobbie
Default Fixed it !!!
Cam shaft sensor and crank sensor fixed it ! Yippee
Old Dec 12, 2010 | 10:07 PM
hydrashocker's Avatar
hydrashocker
Hmmmmmm
Old Dec 12, 2010 | 11:52 PM
agobbie's Avatar
agobbie
Why the "Hmmmmmm" ?? It did fix it beeen driving around most of the afternoon with no issues
Old Dec 13, 2010 | 12:52 PM
hydrashocker
Just good information is all.
I would have thought a bad fuel pump as my 1st choice.
