Another 4x4 problem thread
I got it out of the 2001 Dakota Service Manual, however the 2002 Durango should be the same. Download the Service Manual you want and open the PDF file. Then search for (shift motor). http://www.mediafire.com/?sharekey=c...b5ba589d1986ba
Great. It looks like i need to make sure there is 5V at the mode sensor. If so, then it will be either the mode sensor or the motor but it seems they are sold in an assembly. Thanks again for your help. When i get it resolved it will post the procedure to help others.
I was just looking at a picture of the shift motor. http://www.carpartswholesale.com/inc...IGNvZGUgTlAxLg==
it looks like there is a place that a tool can be inserted into in order to turn the selector manually. What tool fits this? Or is it just a coincidence?
I just found this forum after changing my transfer case motor. Bad idea because when it got stuck in 4hi last year I immediately climbed under and put 12 volts to the 2-wire connection on the motor. It shifted in each direction until I determined that it was in 2hi. changing the unit was difficult because the front driveshaft did not want to collapse as it was supposed to. Forgive me for using force, [ big hammer & 12 inch steel stock]. I did succeed.Any way, waste off time as I learned here. So it sounds like I need the TCCM. or the switch. It is a tough job.
so I replaced the TCCM today
Anyway, I don't know of any "hole", I would just replace the motor/mode sensor.
ru kidding me? did you not comprehend? I only wanted to point out the difficulty ncdurango may have in replacing the shift motor. by the way you may need to remove the crossmember but keep 2 opposing bolts in place & swing it down part way. also, hydracrapper unlike you I don't sit at my comp. all day. please read again. I just found this sight today!
yea hydra, he is correct this time, you misread his post, he didnt find us in time to save him the trouble, while he didnt add anything specific he did confirm what the problem was for him (with what i take to be the same symptoms)
so, if the motor is working, it is possible to put voltage to it and shift it yourself? Is there a way to confirm what position it is in?
I plan to check the voltage at the motor and at the mode sensor this weekend. I will try to clean the contacts just to be sure. If everything checks out, i will apply voltage to see if the motor works. I think i will make a mark on the shaft and the housing so i can see where it was just incase the motor turns and i need to put it back.
However you can shove it where the sun don't shine for the "hydracrapper" remark. I don't have to degrade people to get my point across, I call it how I see it.
