Cosmetic lift?
Old Dec 14, 2010 | 08:29 AM
lucky76jd's Avatar
lucky76jd
Default Cosmetic lift?
Any one have any idea how much height can be obtained by adjusting the front torsion bars? I wanna add a 3" body lift but if I can add shackels and adjust the torsion bars and get a lil more that would work. I will be dooing limited off road, Im looking more cosmetics and low cost.
Jay
Old Dec 14, 2010 | 09:14 AM
Dans01Durango's Avatar
Dans01Durango
I do believe you can crank the torsion up to 2 inches max and then add a 3" lift to get 5 inches for bigger tires. HTH.
Old Dec 14, 2010 | 04:13 PM
hydrashocker's Avatar
hydrashocker
2 inches over correct OEM height to be correct, but yea. https://dodgeforum.com/forum/1st-gen...ment-woes.html
Then you can install a 3 inch body lift for a total of 5 inches.
Old Dec 14, 2010 | 05:02 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup what they said/\
Old Dec 15, 2010 | 10:31 AM
Dans01Durango
(Squawk) Heheheheheeee.....
Old Dec 16, 2010 | 06:50 AM
lucky76jd's Avatar
lucky76jd
Thank you all for the responses.
Jay
