rear heater leak
Old Feb 5, 2011 | 12:49 AM
hydrashocker's Avatar
hydrashocker
Can we say, add this to DIY section?
Old Feb 5, 2011 | 09:34 AM
mnonini's Avatar
mnonini
Default Broken heater door blender
the electric wires run to the two rotating servos (two). They are held on to the assembly by three screws and rotate only one way to open or close the doors. The rear one rotates to heat/air and the front one rotates to open the vents. The doors/blenders are contained inside the black unit and are marked by the white rotater **** under the servos.
Old Feb 5, 2011 | 10:01 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
it was done for 10 hours at the time of your post
Old Sep 9, 2011 | 09:55 AM
laz45's Avatar
laz45
This is an awesome site,you guys have given me so much information......
Old Sep 9, 2011 | 05:31 PM
shrpshtr325
THE ULTI-MOD
thanks laz.
Old Sep 10, 2011 | 01:23 PM
mnonini's Avatar
mnonini
Default Rear Heater Core Leaking
The Dodge part will cost about $120 and it takes only about an hour to remove the panneling and replace it with the part. There is a thread with pictures on clamping the two hoses underneath the right rear and installing the new rear heater core. I suspect mine was damaged by freight that I was carrying in the rear.
