Fog Lamp Electrical Problem
Old Dec 20, 2010 | 08:44 PM
tmdairy's Avatar
tmdairy
Default Fog Lamp Electrical Problem
My fog lamps burnt out last year well actually one of them actually blew. So i waited till now to replace them and after i did i turned them on and nothing happened. The light didn't come on in the dash or anything so my first thought was check the fuse and relay and i did both and they were fine and even switched them with other ones and they still dont work. I was wondering what my next step should be to fix this problem
Old Dec 20, 2010 | 09:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check grounds and plugs at the switch and the lights
Old Dec 20, 2010 | 10:24 PM
hydrashocker's Avatar
hydrashocker
Check the relay in the PDC.
Old Dec 20, 2010 | 10:43 PM
1999_Durango_SLT's Avatar
1999_Durango_SLT
Also did you get that lube for the connection too? I didn't the first time and as soon as I turned my fogs on it was moist air out it blew.
Old Dec 20, 2010 | 11:04 PM
WhiteWidow00's Avatar
WhiteWidow00
My first guess would be to check out the relay since the dash light isn't coming on.
Old Dec 23, 2010 | 05:49 PM
tmdairy's Avatar
tmdairy
I have checked all fuses and relays and even changed them adn there is still nothing. What should be my next step?
Old Dec 23, 2010 | 06:21 PM
logikfive's Avatar
logikfive
The headlight switches are noted to go bad, as well. When I first got my truck it had a bad switch.
New one from Advance Auto was $30-40 and I haven't had an issue since.
Old Dec 26, 2010 | 01:24 AM
Durango03's Avatar
Durango03
Also make sure yur highbeams are off..... haha Sorry, but sometimes its the stupid little things that I, myself forget about!
Old Dec 27, 2010 | 01:22 AM
hydrashocker
I had this same issue and it was the hot wire going to the fogs (just above the split harness) , it was corroded so check for power from the PDC down to the fog light first.
