Attempting to replace my transfer case
Old Dec 21, 2010 | 06:42 PM
cargod1's Avatar
cargod1
Thumbs up Attempting to replace my transfer case
Hello all, Anyone ever replace a Transfer case 01 Durango 5.9 L . Going to give it a shot just try'in to know what I'm getting myself into first, Does'nt seem that bad..... But those could be famous last words !!!
Old Dec 21, 2010 | 09:56 PM
oklahomafbody's Avatar
oklahomafbody
Transfer case is a cake walk. Its heavy and awkward but thats about it. Pretty straightforward. You will need a 10mm hex head for your drain and fill ports. A cheap siphon hand pump for a boat does the job well and screws on to your quart bottle.
The 10MM hex is for a NV242.. you may want to check your tag on the xfer case and see but Im pretty sure these all use the same size.
Also, it uses the same ATF+4 the transmission uses. ***** Always remove or loosen your fill plug first so you can make sure to be able to put fluid back in. Of course you said your completely changing your t-case.
Old Dec 22, 2010 | 03:30 PM
hydrashocker's Avatar
hydrashocker
Incorrect,
The transfer cases limited to that year (2001) is limited to NV133, the NV233 Normal part time case, NV244 which is the AWD case (R/T model.
Fill the case BEFORE you install the new one (1000% easier!) with ATF+4 fluid as indicated.
https://dodgeforum.com/forum/1st-gen...ll-winter.html
Old Dec 22, 2010 | 09:31 PM
SumAmerican's Avatar
SumAmerican
i like 1000%.. that's like getting it perfect 10 times over..
Old Dec 23, 2010 | 02:15 AM
oklahomafbody
I shouldnt post when Im tired. lol sorry, what I meant was I was sure they all used the 10MM allen head, I know theres a million different t-case combos, but thank you for pointing that out, I can see the confusion that may have caused somebody. Again, I dont know if they all have the same size drain/fill plugs either, but thought I read it somewhere when trying to find the size I had.
