Internal Temp and Air Direction!
Old Dec 24, 2010 | 08:46 AM
penick33's Avatar
penick33
Exclamation Internal Temp and Air Direction!
Just when I thought my D was perfectly sound. I was driving yesterday and I noticed that my temp control is stuck on HOT and it will only blow on the floor. I can adjust the fan speed ONLY! But the temperature AND direction wont change at all. Anyone run into this before? I have an eight hour drive after Christmas and on my way up North my feet sweated to death while my windows were down. Someone has to know something about this.
Old Dec 24, 2010 | 09:04 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
probably a bad connection to the actuators which control the blend door/directional door, or it could be a broken door, the actuators can be accessed w/o taking the dashboard apart, the doors themselves cannot
Old Dec 24, 2010 | 11:18 AM
penick33's Avatar
penick33
Look into the actuators huh? Will do, how often have you heard of both the temp and directional malfunctioning together?
Old Dec 24, 2010 | 02:14 PM
shrpshtr325
THE ULTI-MOD
i havnt, but ya never know and its an easy check
Old Dec 24, 2010 | 06:31 PM
penick33's Avatar
penick33
I dont have my Haynes with me, do you think you could tell me how maybe? If not its all good and I will be home in a couple days and check then. Thanks Sharp.
Old Dec 24, 2010 | 10:32 PM
shrpshtr325
THE ULTI-MOD
http://www.mediafire.com/?2cg2hgim2zz
it should be in there, if not i unfortunately cant help you very much, sorry.
Old Dec 25, 2010 | 01:04 AM
markmca's Avatar
markmca
can you hear the directional actuator running when you change positions? Mine got stuck on defrost and all it was the rod came off the track on the actuator.
Old Dec 25, 2010 | 10:09 AM
penick33's Avatar
penick33
No, I cant hear anything when I switch the temp control or the direction of the air.
P.S. your the man sharp!
