Heat/ac blower problem
Old Jan 8, 2011 | 07:33 PM
hd54's Avatar
hd54
Default Heat/ac blower problem
Have 2001 durango. Blower worked fine til all of a sudden stopped working. Rear works fine. Checked all fuses inside and under hood all ok. Is it the blower moter or something else. Had fan adjustment issues 2 years ago changed module fan speeds ok. Could it be the same problem?
Old Jan 8, 2011 | 08:13 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds like the blower resistor is bad (im assuming you are talking about the front blower motor) should be under the glovebox on the passenger floor board $12 part from the stealership
Old Jan 9, 2011 | 06:06 AM
hd54's Avatar
hd54
Smile Heater blower
Thanks i will replace that
