Trans question
Old Jan 8, 2011 | 09:48 PM
Dig-N-Deep's Avatar
Dig-N-Deep
Default Trans question
when im on the freeway doing 60-70 any were in there if i put it on cruise controll the rpms go from like 2k to like 2300 or 2400 up down up down like 3-4 times the its fine for a few min then it will do it again and if i just hold it with my foot insted it only does it once in a while like every 10-15 min or so any ideas thanks in advance
Old Jan 8, 2011 | 10:33 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
not a trans problem it is your tps (throttle position sensor) replace, and reset the PCM and you should be fine
Old Jan 9, 2011 | 12:50 AM
Dig-N-Deep's Avatar
Dig-N-Deep
ill try that thanks bud hope its the tps and not any trany stuff i dident think it was the trans cuz it shifts great up and down thanks again bud
Old Jan 9, 2011 | 09:25 AM
shrpshtr325
THE ULTI-MOD
np, this is the most common 'classic' symptom of the TPS going bad, make sure to reset the PCM after you change the sensor
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
Old Jan 9, 2011 | 10:35 AM
Dig-N-Deep's Avatar
Dig-N-Deep
thanks i have a scanner with live data and i can watch my tps and stuff so maybe i will jump on the freeway with it hooked up and see if thats it and thanks for the info bud i will put a new on on anyway but i wana see if it jumps on my live data streem
Old Jan 9, 2011 | 10:54 AM
shrpshtr325
THE ULTI-MOD
sounds good, let us know what you find out
