Durango 46re trans problems
Old Jan 12, 2011 | 07:13 PM
wallleyewolf1@aol.com's Avatar
Default Durango 46re trans problems
I just went through trans and replaced all clutch dics and steels, and all seals accompanied with this. The vejicle goes great in reverse , but is slipping terrible in all forward gears. Help
Old Jan 12, 2011 | 08:30 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ill move this to the 1st gen section for you
Old Jan 12, 2011 | 09:07 PM
WhiteWidow00's Avatar
WhiteWidow00
I'd adjust the bands as they sound like they're out of adjustment and I'd also do a complete fluid and filter replacement (not just flush) as there could be some contaminants in the fluid.
Old Jan 12, 2011 | 09:15 PM
shrpshtr325
THE ULTI-MOD
and do NOT flush the transmission, a purge just changes the fluid and is acceptable, however a flush will cause problems
Old Jan 13, 2011 | 10:22 AM
Dans01Durango's Avatar
Dans01Durango
+1 on the flush. DO NOT flush. Just have them change out the tranny fluid. Mopar ATF+4 or Valvoline ATF+4, which is Mopar approved.
