Cleaning headlight lenses
Old Jan 16, 2011 | 06:30 PM
dolittle's Avatar
dolittle
The 3m is the best. You well need a good drill. shrpshtr is right one with this. I did mine two years ago and they are still good. Read the directions take your time and let us know.
Old Jan 16, 2011 | 09:50 PM
CtownChris's Avatar
CtownChris
Tooth past, the old fashion white paste not the jell stuff and some elbow grease.
you'd me amazed at the improvement.
A little buffing like a basic 10 inch pad helps too.
Old Jan 16, 2011 | 11:43 PM
sparkmarv's Avatar
sparkmarv
+1 on the tooth paste, buddy of mine did it to his, works well, and yes the old plain white PASTE.
Old Jan 16, 2011 | 11:50 PM
Biff85ta's Avatar
Biff85ta
I would think fine polishing compound would work about the same as toothpaste.
Old Jan 17, 2011 | 12:55 AM
WhiteWidow00's Avatar
WhiteWidow00
It does toothpaste is just generally cheaper and found more around the house to the typical person.
Old Jan 17, 2011 | 11:30 AM
coreybv's Avatar
coreybv
That's because toothpaste IS a fine polishing compound. Just an edible one. The paste (not sure about gel) does have a very fine abrasive in it.
Old Jan 22, 2011 | 06:24 PM
TOMMYB's Avatar
TOMMYB
update on the headlight cleaning. used the toothpaste (colgate travel size from wally world- 97 cents) and an old toothbrush. that got the top coat off. i used the cordless drill on low speed and a cleaning kit i got at napa for cleaning headlights. the two together worked great, head light lenses are nice & clean...and minty fresh. LMAO.
Old Jan 23, 2011 | 12:39 AM
01 6.3L RT's Avatar
01 6.3L RT
