wont start
Old Jan 16, 2011 | 09:30 PM
hydrashocker's Avatar
hydrashocker
She could have broken the plug end on the coil wire. Replace the coil wire and check the power plug harness to the coil.
As for why, I have drawn my own conclusion to the reason:
Old Jan 17, 2011 | 09:20 PM
tattman37's Avatar
tattman37
I'm having firing problems. my truck wont start. getting fire, but not very strong or as much as needed. firing strong from coil to distributor,gets weak after leaving distributor.any suggestions!! already changed plugs.
Please, any help would be much appreciated.
Old Jan 17, 2011 | 09:27 PM
samnbensdad's Avatar
samnbensdad
What year, engine size, etc...? Is this a new problem? You'll need to give more info...
Old Jan 17, 2011 | 10:11 PM
tattman37's Avatar
tattman37
Default year, make and model
Sorry, its a 1998 durango, 5.2 ltr
Old Jan 17, 2011 | 10:12 PM
tattman37's Avatar
tattman37
would changing dist.cap, rotor and plugs help?
Old Jan 17, 2011 | 10:38 PM
Fox Fader's Avatar
Fox Fader
Rotor, wires, cap.
samnbensdad
I was hoping some of our veteran members would jump in but... Yes, anytime you change spark plugs, you should change the wires, cap and rotor. Also, what plugs did you use? You should stick with OEM Champion copper core at 0.040.
Did this problem just start?
Old Jan 17, 2011 | 10:51 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yes, start out w/ new plugs (copper core, champion plugs gapped to .040, check you manual, or underhood sticker for correct part #) wires(mopar, or MSD 8mm or better), cap, rotor (brass contacts only)
if that doesnt take care of it get a new coil
Old Jan 17, 2011 | 11:27 PM
tattman37's Avatar
tattman37
Default Thanks to all
Thank you for your help! I will change cap, rotor, and wires tomorrow. i used Bosch platinum plugs. Don't know about gap.
Old Jan 18, 2011 | 01:13 AM
oxygen454's Avatar
oxygen454
Getting fire? As in spark and fuel? If so then it should run, unless it wont stay running?
Also make sure the wires are on right. If the wires are on the distributor wrong, the firing order will be messed up causing the truck to not run or run extremely rough.
Also you should try posting in the Durango area, you will probably get more support there.
