Need Help Removing My Transfer Case
Old Jan 17, 2011 | 02:55 PM
brians1bad72's Avatar
brians1bad72
Default Need Help Removing My Transfer Case
I have a 2000 Durango 5.9L, I need to remove the transfer case to pull the transmssion, the trans. is slipping and needs rebuilt. I have the driveshafts removed, the question I have is what bolts to remove to remove it from the trans. I see some nuts right off the back of the trans. but the top nuts are almost impossible to get at without lowering the trans. Are those the bolts I am suppose to be removing? There are what looks to be about 8 of them. My transfer case model is a 231. Thanks.
Old Jan 18, 2011 | 12:56 AM
brians1bad72
Ok I pulled the transfer case out myself, mission accomplished. No need to respond.
Old Jan 18, 2011 | 01:32 PM
hydrashocker's Avatar
hydrashocker
Glad to see you got it, and to add I think there are 4 bolts at the marriage ring between the trans and T-case.
