lowbeam toggle
Old Jan 27, 2011 | 04:54 PM
bowhuntmaine's Avatar
bowhuntmaine
Default lowbeam toggle
I keep losing my lowbeams. The accessory switch on the steering column has been replaced 4 times. When it happens, i turned on the headlights and nothing, jiggle the accessory switch and usually they will come on.
This is annoying, so i was wondering about rewiring the headlights and putting them on a toggle switch mounted to the dash. Your thoughts are appriciated. Also, can the lowbeam and high beams being separated or are they on the same wire?
Old Jan 27, 2011 | 06:11 PM
jmess's Avatar
jmess
have you tried replacing the relay for the headlights?
Old Jan 27, 2011 | 06:37 PM
hydrashocker's Avatar
hydrashocker
+1 on the relay.
No, the switch (with lots of wires) goes into the CTM so there are simply too many wires involved. To better fix your problem, simply find the short and fix it correctly.
Old Jan 28, 2011 | 10:11 AM
bowhuntmaine
Thanks guys, going to work on finding the problem this weekend. will post how it goes.
Old Jan 29, 2011 | 01:31 AM
IndyDurango's Avatar
IndyDurango
Uhhh... what "accessory switch on the steering column"? The multifunction stalk?
IndyD
Old Jan 29, 2011 | 09:30 AM
bowhuntmaine
Yep, thats the one. Why did they have to place the dimmer there? I'd much rather have it on the floor.
Old Jan 29, 2011 | 09:54 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i may be on the young end here, but every vehicle i have drive has had the low/high beam switch on the steering column . . .
Old Jan 29, 2011 | 01:01 PM
WhiteWidow00's Avatar
WhiteWidow00
My '86 Ram 150 had it as a button on the floor by the parking brake. It was always fun when someone cut me off to stomp my foot as I'm flashing them.
Old Jan 29, 2011 | 01:39 PM
hydrashocker
I STILL do that!........LMAO
Too many years of hittin that damn floor button in my old truck.
Old Jan 29, 2011 | 02:57 PM
IndyDurango
I think the floor high beam stomp-switch is the single thing I miss the most in modern autos.
IndyD
