99 5.9 durango died while driving-wont start
Old Jan 30, 2011 | 04:40 PM
winerig's Avatar
winerig
Default 99 5.9 durango died while driving-wont start
engine just shut off. battery tested good. alternator tested good. new cap and rotor. still wont start. it did fire up for a second or two befor cap and rotor, was rough and died quickly, now nothing.
223,000 miles
Old Jan 30, 2011 | 04:49 PM
WhiteWidow00's Avatar
WhiteWidow00
Typical symptoms of either stuck IAC or CPS.
First off, start with cleaning the IAC head and port. Next if nothing, replace the CPS.
Originally Posted by hydrashocker
How to Clean the IAC Solenoid:
This is recommended at every Tune-Up to prevent excess carbon buildup on the IAC plunger. In some cases, you'll notice a slightly erratic idle quality. This is the first step in taking care of that problem. IAC = Intake Air Control (Solenoid).
1. Remove the Air Hat from the Throttle Body
2. Disconnect the sensor harness from the IAC Solenoid (Rear of Throttle Body)
3. Remove the two Torx-25 Screws
4. Remove the IAC Solenoid (Be careful not to lose the rubber O-Ring)
5. Spray some Carb/TB Cleaner in the IAC port on the Throttle Body and let it sit
6. Spray some Carb/TB Cleaner on the tip of the IAC Solenoid and wipe clean (Do NOT forcefully twist or push the plunger - You will damage the Solenoid. Wipe very gently.)
7. Spray a little bit more Carb/TB Cleaner in the IAC port on the Throttle Body and wipe clean with a thin/lint-free rag
8. Reinstall the IAC Solenoid (Make sure you don't lose the rubber gasket on the solenoid)
9. Reinstall the sensor connector and airhat
10. Reset the computer: Engine Code Index (Check Engine Light?)
Old Jan 30, 2011 | 05:24 PM
winerig's Avatar
winerig
going to clean IAC. what is CPS
Old Jan 30, 2011 | 05:33 PM
WhiteWidow00
Crankshaft Position Sensor
Old Jan 30, 2011 | 07:38 PM
winerig's Avatar
winerig
strarting to think its the fuel pump-thanks for all the ideas.
Old Jan 30, 2011 | 08:29 PM
hydrashocker's Avatar
hydrashocker
Could be a fuel pump......Check for pressure.
Old Jan 30, 2011 | 08:50 PM
WhiteWidow00
Like hydra said, check fuel pressure from the service pressure check port on the driver side and should be in the range of 50-54.
Old Jan 31, 2011 | 08:20 AM
bowhuntmaine's Avatar
bowhuntmaine
Mine did that a few years ago, my coil melted to the point that it was running out on the ground. I'd check that too.
