lazy alternator
Old Feb 21, 2011 | 05:24 PM
jaydubyagee's Avatar
jaydubyagee
Default lazy alternator
My alternator is sleeping on the job. First noticed an issue today when my "check gauges" light came on and saw the voltmeter registering at about 8-9V. I restarted the vehicle and the gauge slowly climbed to just past 12V and held there. Measuring at the back of the alternator, I'm only showing 12.1V steady. The battery is showing 12V across the terminals (i'm in year two of an 8yr duralast gold, so I'm working with the assumption it is fine).
Do I have a dying alternator?
Old Feb 21, 2011 | 05:36 PM
dolittle's Avatar
dolittle
I would have the alternator and battery tested.
Old Feb 21, 2011 | 05:43 PM
WhiteWidow00's Avatar
WhiteWidow00
It sounds to me like a lousy alternator. I'd get it tested at AZ or Advance and also get the battery tested under load.
Old Feb 21, 2011 | 06:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup i agree that it sounds like a dying alternator, iirc they should be putting out about 14v with the engine running
Old Feb 21, 2011 | 06:32 PM
WhiteWidow00
14.4v, but close enough shrp LOL
Old Feb 21, 2011 | 06:39 PM
shrpshtr325
THE ULTI-MOD
ahh, i doubt the battery would notice less than 1/2 a volt of difference
Old Feb 22, 2011 | 01:02 PM
jaydubyagee
wouldn't you know, a good night's rest and the alternator is now putting out 14V. If only it was that simple.
Old Feb 22, 2011 | 03:39 PM
WhiteWidow00
Yeah I know, very unlikely.
For future reference to whom it may concern, this is where the voltometer should read when all is working well:
Old Feb 22, 2011 | 04:19 PM
hydrashocker's Avatar
hydrashocker
+1 Sounds like a bad alternator.
As for the battery, I'm sure it's fine.
Old Feb 22, 2011 | 09:44 PM
shrpshtr325
THE ULTI-MOD
and this is what the dash looks like in the new gen trucks w/ everything running correctly (it was like 10 degrees out this day, just fyi as the idle is a little high in that pic, usually sits exactly on the 500rpm line)
