my cruise control does not work i hit the button one time and the light flikers on and then goes off i replaced the clock spring. same thing any ideas thanks johnnynitros
Check fuses in the door jamb fuse panel first off. Next check vacuum lines to the main cruise control unit. If theres any frayed wires or a vacuum line is broke or ripped it will cause problems.
